OEM rear sway bar sizes..?
Been searching, but I can't seem to find the info I need. I just have a simple question, does anyone know the sizes of available OEM rear sway bars for my EG hatch?
How thick is the 92-95 Si rear sway bar? Are LS and GSR rear sway bars the same thickness? How thick are they? I know most people around here just go for the ITR bar upgrade, but I'm thinking that perhaps it might be a little too much overkill for my featherweight CX hatch. As of right now my car is completely stock, but since I have plenty of time before I can start paying for mods, I'd like to research heavily into every subject before I make a decision. I've been getting into Auto-x a lot recently, so that's about the only track time it will see. It's a daily driver. I just don't like the idea of having such a stiff bar as the ITR while I'm driving down the freeway, or doing some major highspeed turns. As of right now the car is VERY forgiving when I'm pushing it in the turns, and while I do want to reduce the body roll a LOT, I DON'T want to have a majorly twichy rear-end. If it makes any difference, I've been considering going with 'sport' Omnipower coilovers - mostly for the performance per dollar factor. I'm just trying to find an exceptional balance between feel, performance, and price. Thanks everyone! All opinions/comments are welcome... I also posted this in the autocross/roadrace forum incase you noticed... Modified by MrTodd at 12:29 PM 5/24/2005 |
Re: OEM rear sway bar sizes..? (MrTodd)
integra stock sway bars are 14mm, as well as the civic si's. the american ITR has a 22mm rear sway, and the JDM ITR has a 23mm sway
Re: OEM rear sway bar sizes..? (rukawa1one)
Thanks for the reply!
I'm thinking that while a 14mm bar would definitely be beneficial over having none at all, it would seem like it's a little too thin/flimsy for what I would like. Maybe I'll have to start looking at aftermarket alternatives for something inbetween the ITR and the lesser 14mm bars... |
Go here: http://www.knology.net/~jediklc/ then click on the technical info link.
Re: OEM rear sway bar sizes..? (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rukawa1one »</TD></TR><TR><TD CLASS="quote">integra stock sway bars are 14mm, as well as the civic si's. the american ITR has a 22mm rear sway, and the JDM ITR has a 23mm sway</TD></TR></TABLE>LS is 13mm, GSR is 14mm.
em1 is 13mm
Re: (pdiggitydogg)
13mm also comes on certain 92~95 4 door sedans.
Re: (_BEN_)
Hey thanks for the input everyone! This helps big time! https://honda-tech.com/forums/images/smilies/emthup.gif
On my Si, the stock sway bar feels a little weak..im thinking of upgrading to the ITR..only heard good things about it. Just make sure ur re-enforce ur subframe.
I also have a quick question, for the 00 Si, if I want to install a ITR sway bar, should I also re-enforce my subframe? Or is it ok since I already have a factory Sway bar? |
^Yes, reinforce. The em1 only has the plates on the back/inside of the subframe.
I can say its like night and day from 13mm to 22mm https://honda-tech.com/forums/images/smilies/emthup.gif |
aiite thanks man..helps a LOT https://honda-tech.com/forums/images...es/emsmile.gif
