OEM LED Spoiler just stopped working.
My OEM spoiler on my 97 HX just stopped working. Its power line is hooked up to one of the brake lights on my trunk. All the other four brake bulbs work and since it is tapped into one of them, I am pretty sure that the LED assembly needs to be replaced or fixed. I am certain it is not a wiring problem. Does anyone know how if I could replace seperate bulbs or do I have to replace the whole thing? Where would I buy it?
Re: OEM LED Spoiler just stopped working. (PhatBoy5015)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PhatBoy5015 »</TD></TR><TR><TD CLASS="quote">My OEM spoiler on my 97 HX just stopped working. Its power line is hooked up to one of the brake lights on my trunk. All the other four brake bulbs work and since it is tapped into one of them, I am pretty sure that the LED assembly needs to be replaced or fixed. I am certain it is not a wiring problem. Does anyone know how if I could replace seperate bulbs or do I have to replace the whole thing? Where would I buy it?</TD></TR></TABLE>
If it is one LED that is gone you can replace it if you know how to solder. One LED gone will cause all to not light up (depending on how it is wired up) You should visually be able to visually tell if it is a burnt out LED.
Re: OEM LED Spoiler just stopped working. (old man neri)
Well, I just drove to my friend's house and the LED worked when I was driving over there. Then when I was coming back to my house, it didn't work until I was almost all the way home. I thought that there might be a loose connection, but I didn't hit any bumps or anything to cause it to work or not work. It just works randomly. This sucks.
fryman
12-02-2014 12:44 PM
