OEM Fuel pressure regulator question.
I think my FPR is going bad as I'm running rich all of a sudden. I have another oem FPR but am not sure which motor it came off. I think it might be off of a dohc zc as it looks identical to it. Funny thing is it looks also identical to the z6 reulator.
Same as z6 or what?
Same as z6 or what?
Re: OEM Fuel pressure regulator question. (Mr.Death)
Factory FPR don't usually just go bad. Before you start replacing parts, find out exactly what is wrong. Hondas run rich by nature, if it's worse it may be a o2 sensor and will throw a code once it gets bad.
Re: OEM Fuel pressure regulator question. (fast95eg8)
It says NR1 on the side. I gave it a little rub with steel wool and it cleaned up nicely.
And yes my hand writing sucks, very observant of you. I'm suprised you didn't notice the resin on the scissors
Does anyone know if the internals of the zc fpr and the z6 are the same? They look the same but apparantly have different ratings. d16z6 40-47 psi and zc 33-39 psi.
Re: OEM Fuel pressure regulator question. (sicones)
D'oh.. I don't have a fuel pressure tester handy so I thought one of y'all would have the answer. They look the same but are they..
