OEM Fog Light Wiring Problems.. Only 2 wires to go....
OEM Fog Light Wiring Problems.. ONLY 1 PLUG TO GO!!! NEED HELP NOW!!
I've almost got my OEM fog lights for a 1999 Honda Civic 2dr installed. But There are two plugs left that I have to put into some thing. I have now clue where these tow plugs go?? There brown single pin plugs. They fit into the Fuse box but I'm not sure which hole to plug them into??? If you know ne thing about the OEM Fogs let me know. I've been trying to figure it out for a few days now but just can't. Thanks.
1999 Honda Civic GSR/Type R
Modified by GReddyjon at 9:53 PM 2/20/2006
Re: OEM Fog Light Wiring Problems.. Only 2 wires to go.... (GReddyjon)
if u look under the foot area u see the fuse box..which i think u see alreadie u'll see i think five fuse things where u can plug it in..going from left to right..count to the second one and then use that one..thats just wut i did..hope that helps
Re: OEM Fog Light Wiring Problems.. Only 2 wires to go.... (krazyhmongboi)
Ok thanks.... I just went outside and put one of them into the second fuse hole and got power to the Fog light switch. Now I have one more brown plug that have a slightly thicker white wire. Which fuse hole does this go into? Thanks.
I only have one plug to go and then my fog lights will be complete. I've been trying to get them to work for like a week now. I have one last brown single prong plug.... where does it go in the fuse box???? Thanks
Re: (GReddyjon)
http://www.cardomain.com/ride/2231110/6
Go to this web page and see the pics of what I'm talking about.
Some one has to know what I'm talking about.
Which of the last 3 plugs does this go into???
I just took those pics like 5 min ago. I really need to get this done. If ne body has OEM Civic fog lights help me out. I need to know where the last brown single prong connector goes?? Thanks.
Re: (GReddyjon)
The only help I can give is this...
http://handaaccessories.com/ci...s.pdf
Try page 8 or 9. Looks to be somewhere in there. GL
JasonGhostz
JasonGhostz
Re: (JasonGhostz)
Thanks. But I already got that last nite. That helped me big time through most of the installation but now I'm stuck again. I need to find out where in the hell this last brown pin goes. I've tried every plug in the fuse box but none of them work. Thanks for your help.
Re: OEM Fog Light Wiring Problems.. ONLY 1 PLUG TO GO!!! NEED HELP NOW!! (GReddyjon)
Are the brown connectors labeled with a number? My OEM ones for my EG were labeled with a number on the brown connector. Then I just matched the number on the connector with the number labeled on each of the accessory slots on the fusebox.
Re: (GReddyjon)
well here this is wut i did to mine..u may have alreaide done these things but mayb it'll help u
-put the relay switch and the red wire close to ur batt.
-connect ur foglights up
-connect ur ground wires.i think theres two of them..mayb one inside and one inside
-connect ur relay switch inside on the empty spaces by ur power mirror switch(if u have, or where u wish to put them)
-put the one pin fuse connector in the second fuse like i said earlier
-connect the relay switch and put in the red wire in the battery.
-try it out to see if works
i think thats it..i'll check my set up tonite and get back at u if this doesnt work for u..hope it does
I dont' think he's wiring them up like you, it sounds like his car has the wiring harnesses all ready for fog lights, jsut that there wasn't fog lights installed
Re: (Syndacate)
Exactally, I have everything hooked up like it came from the factory. There OEM 99-00 Honda Civic Fog Lights. They do attach to the cars origional wiring harness. I just have one last brown connector that has to plug into the fuse box some where. I've got power to the switch but need to get the poweer from the switch to the lights. If ne one can help me out. I'd really appricate it. Thanks.
k what so far is hooked up give us colors and where they are hooked to, IE: red is at the battery, where is the white wire going?, it plugs into something at the other end. i hooked mine up too my EG in about 10 min, so hopefully i can help
Re: (D15Bbigred)
Theres nothing going to the battery. The fogs connect directly behind the left side headlight. Then the button itself connects to the fuse box. Its not some kit I just bought from the store.
wow i cant believe no one gave u the correct answer this is honda tech lol .if u look behind ur fuse box there is a brown plug taped to it with blue tape oem from honda.pull it down and plug in that brown plug u got hangin there ur good to go
Re: (LsVtakYO)
Yea I already did that. Took the blue tape off and pluged the brown connector into it. But theres still one more plug left to plug in. Its a single pin brown connector. I'm takin it to get a system put in it so I'll see if they can help me out. If you wanna see pics of wat I'm talkin bout check this link out...
Thanks
Thanks
Re: (GReddyjon)
that instruction get me nowhere for the inside harness. i look under the fuse box still i cant find that brown pin with blue tape. can some expert here help me out? i need to see images that would be a great help.
JasonGhostz
JasonGhostz
amej8
16
01-04-2007 08:02 PM
