oem fog light question
ok so i was reading a how-to on hooking up oem knock off jdm fog lights and i ran into a lil problem... it says in one part of the directions to locate the one pin plug blue taped tot he car harness next to the fuse box... well i located my wire and its a two pin plug that was blue taped.... if anyone could shine some light on this situation it would be greatly appreciated or hit me up on AIM jdm1piece
Re: oem fog light question (droppedeg6hatch)
I ran into the same issue but just keep looking back there ull find the right one i belive the plug was brown . . it was behind the fuse box on the left side
I see you have an EG. Most 92-93 models will NOT have the plug behind the fusebox, and you'll need to run that wire through the firewall manually. On the other hand 94-95 models will have that plug, and just keep looking.
I have a 92 VX, and it didn't have have the plug near the windshield washer fluid reservoir or behind the fusebox.
well actually i dont have an EG i made this screen name before i knew what i was talking about lol... i have a 1995 honda civic ex coupe- which means i should make a new screen name, but if the plug is back there will it be taped to anything or is it just hard to find... im hoping i didnt waste all this money on oem foggies an now i gotta semi- hard wire them in when the kit said plug and play
I have the ebay fog light in my ej1. Everything was plug and play. So are you trying to feed the wire through the firewall? Or are you talking about the fuse box on the engine bay or under the dash fues box?
Re: (turb20_vtec)
i have instructions that i got offline from some website... i forget the name of it... but it says locate the 1 pin connector blue taped to the cars harness underneath the dash near the fuse box, and i found a plug blue taped tot he cars harness but my plug has two wires going into it- neither of which match the colors in the instructions... so im kinda worried that im gonna have to ghetto rig something- otherwise i have located every plug that i need to plug the rest of the harness in
got no idea what your talking about blue wire. i got my fogs from ebay and the wiring was messed up so i just wired them to my corner lights. but it should be plug and play, cousin got aftermarket brand and it was plug and play. pm me if you want the step by step on how i did it.
Re: (droppedeg6hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by droppedeg6hatch »</TD></TR><TR><TD CLASS="quote">where do i run the wire to and from??? sorry if i seem a lil retarded</TD></TR></TABLE>
You have the fog harness which gets power from the fusebox via the switch harness. The fog harness plug ends up to be near the driverside headlight. You take 16 gauge wire, connect it to the fog harness using a female spade connector, run it along the driverside of the engine bay. There's a firewall grommet that has a bunch of wires going through it near the clutch master cylinder. Run that single wire through that grommet, through the firewall, and connect it to the switch harness via a female spade connector.
DOMAN!EJ8
16
09-02-2009 10:17 PM
Schultzie
05-01-2007 04:25 AM
amej8
16
01-04-2007 08:02 PM
CivicSiRracer69
03-29-2004 05:43 PM
