Odd EG cruise control problem
I'm having a little trouble with the cruise control in my 93 Civic.
My cruise control has not worked since I got the car. I switched out the cluster bulb, went for a test run, and I seemed to had gotten it to work. I hit the brake pedal, it flickered, and shut off. When I went to turn it back on, it stopped working again and has not worked since. I checked the cluster bulb and it looks just fine.
Does anyone have an idea of what could be causing this?
Re: Odd EG cruise control problem
Error in service manual -- There's a discrepancy between the CC circuit diagram and the brake switch test.
The circuit diagram indicates that there should be continuity between A-B with pedal depressed and continuity between C-D with pedal up.
Ah, OK. Since there's no contact between those, then it would be the switch. Sounds like it's time for a trip to the u-pull.
Well I went ahead and switched out the pedal switch. I still got nothing.
I also forgot to mention that it wasn't till I released the "set" button that it kicked in when it worked.
tangopampa
04-24-2015 07:45 PM
usdmEHboy
02-01-2006 08:30 AM
