odb2 harness help
i recently swapped in jdm d15b and i wanted to use my obd2 harness and ecu and then i ran into some problems so im jsut going to get a p08 ecu and a jumper harness
my question is this, i swapped out all of my obd1 sensors for obd2 sensors and distributors to make it work, but since i am going back to obd1 ecu do i need to convert all of those back? and also i noticed that the oil filter that came on the motor is really small, can i use the ones for my y8 or do i have to get different ones? thanks Jesse |
Re: odb2 harness help (97DGreenEx)
so your going to have an OBD2 sensor'd engine w/ an OBD2 harness....and your going to have an OBD1 ecu. is that right? so couldnt you get an OBD2 to OBD1 jumper harness? or am i reading you question wrong
Re: odb2 harness help (FifthGearOnline)
ya ive got an obd2 to obd1 jumper harness i jsut need to know if i ahve to switch the sensors and distributor back to obd1 stuff
thats what the jumper harness is for. i was going to use an OBD1 - OBD2 jumper harness on my b16 since i had an obd1 engine and my civic was obd2
the distributor will be fine, so should the sensors
