OBDIIb - OBDI conversion harness
Old 04-22-2005, 12:50 PM
specv5150's Avatar
Default OBDIIb - OBDI conversion harness
here is my situation. I bought a OBDIIb to OBDI conversion harness last month and I bought a chipped P28 a couple weeks after that. Anyway I finally got around to converting to OBDI as part of my turbo setup. The female side of the plug goes right into the P28.
However
The male side does NOT mate up to the engine harness.
Here is a pic of a similar conversion harness...
https://honda-tech.com/zerothread?id=1140644
The small plug on the engine harness side has the MAP, TPS, etc, so the car wont start right now. I know I am running a 5wire O2 right now but that wouldnt stop my car from starting. Am I missing something or do I have the wrong harness?
Old 04-22-2005, 01:27 PM
specv5150's Avatar
Default Re: OBDIIb - OBDI conversion harness (specv5150)
I think I have it figured out
I have a 2000 Honda Civic HX which everyone thinks....99-00 is OBD2b
HOWEVER
After searching here
http://www.hondata.com/techecuid.html
and here
http://www.ag-eng.com/ (go to the FAQS section, then the how to identify your ECu section)
And you will see that not ALL 2000 civics are OBDIIb. My HX is OBDII ("A" I guess for all intents and purposes)
My P2N has pinouts in the 1st slot, 3rd slot and 4th slot which designates OBDIIa (the 2nd slot would would used if you had an automatic tranny)
OBDIIb is 1st, 2nd and 3rd slot..with the 4th slot being empty (unless you have an automatic transmission). So I guess I know why one of my plugs doesnt line up and my car wont start. Lesson learned...dont beleive everything you read on the internet....even on the beloved Honda Tech
germanegturbo
09-27-2008 06:22 PM
invisible
11-19-2006 09:23 AM
BigIslandBoi
08-12-2003 03:27 PM
romeo619romeo
03-28-2003 09:54 AM
Quick Reply: OBDIIb - OBDI conversion harness
