OBDI or OBDII in civic ek4 96 (d16y8) ???
Hello guys i have a question in the same subject:
I own a civic coupe 96 D16Y8 engine now my friend told me that there is a possibility that the Electrical system is OBDI and not OBDII as i fought until now !
i attached a picture of my car (http://hondaswap.com/hybrid-eg-ek-dc...53/#post880622).
How can i check which OBD r my car using ??
Its very important cause im going 2 do a b18c or b16b swap so i have to know !
Thanks.
Thanks.
Re: OBDI or OBDII in civic ek4 96 (slo_hatch)
All USDM 96+ Honda Civics were OBD-II.
You can verify this (in an obvious sense) 2 ways, one, there should be a big *** O2 sensor sticking out of your catalytic converter - it's quite obvious. Two, there is an OBD-II scanner access port under your dash, parallel with the gas pedal, on the left hand side (almost all the way to the wall).
I highly doubt somebody converted it to OBD-I.
They could just be running an OBD-IIa to OBD-I conversion harness with an OBD-I ECU, but that's a far cry from an "OBD-I conversion."
For confirmation on that you'll see about 8in extra of wires by the ECU.
Re: OBDI or OBDII in civic ek4 96 (Syndacate)
Well Guys yesterday i lifted my car i saw the first O2 sensor in the header and searched the second near the convertor but there isnt one !
So what does it says ?? my car is OBDI ?
Maby the civic 96-98 in Israel is OBDI ?
Help anyone ?
Help anyone ?
Re: OBDI or OBDII in civic ek4 96 (loverboy)
Pull the carpet on the passengers kick panel and look at the ecu, on its side there should be a number that starts with "P"XX . Post that number and well tell you what it is.
Re: OBDI or OBDII in civic ek4 96 (ejoner)
Hey !
Well I have checked the ECU the number is P2P, so my engine is OBDI or II ?
If its OBDII how can it be i have just 1 O2 sensor ??
gmanns
12
12-09-2020 09:02 PM
laperriere
11
05-27-2012 08:56 PM
