obd2 wiring harnes, obd1 motor
what up HT, i obviously know that a obd2 wiring harness will not go into a obd1 motor perfectly, but what i want to know is what sensors, or cables will need to be changed or adapted to fit a obd 1 motor, i have a 2000 ex but i just bought a d16z6 with a d16zc head...can anyone help?
Technical Hero
Re: obd2 wiring harnes, obd1 motor
-intake air temp sensor (obd2=square, obd1=round), reuse y8 manifold problem solved
-evap purge (same as above)
-z6 has no crank fluctuation sensor by the crank pulley, you'll have to bypass unless you run an obd1 ecu
-reuse your injectors and alternator
-distributor wont plug in, you can use the y8's but it all 3 bolts won't line up
-z6 has no knock sensor which won't matter if you use the obd1 ecu
SovXietday
09-16-2008 08:34 PM
00WhiteEKy
10-21-2004 11:11 AM
