for the OBD2-OBD1 guys .........
Re: (soccaian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soccaian »</TD></TR><TR><TD CLASS="quote">you don't have to relocate the ecu... just try putting it in different positions to get the wiring harness out of the way.</TD></TR></TABLE>
Yeah...shove the wire harness upward or something.
Re: for the OBD2-OBD1 guys ......... (maztur)
well i had the same problem. there is no chance at fitting that huge ecm in the stock location. the guys at the stereo shop were gonna make me a false floor to mount it under. but i was looking, and it looks like u could easily just drill it up to the underside of the glove box.
yeah, Im going to figure out a way here soon, because im tired of telling people to watch there step,I might do what FBP Si 2000 said, and shove it upwards
Re: (Shaun)
Just put it at a slight angle, with the harness end to the top. The corner is touching the floor board. Let the conversion harness hang down. Mine fit behind the stock kick panel.
what is needed exactly to convert from OBD2B to OBD1?
just the special harness?
n00b to conversions like this
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maztur »</TD></TR><TR><TD CLASS="quote">Anyone put it in glovebox, pics?</TD></TR></TABLE>
I'd like to see this.
Re: for the OBD2-OBD1 guys ......... (FifthGearOnline)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline »</TD></TR><TR><TD CLASS="quote">what is needed exactly to convert from OBD2B to OBD1?</TD></TR></TABLE>
Whats your setup? OBD1 motor in a OBD2 car?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FifthGearOnline »</TD></TR><TR><TD CLASS="quote">just the special harness?</TD></TR></TABLE>
Special harness?
Special harness?
Re: for the OBD2-OBD1 guys ......... (turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbogixxer »</TD></TR><TR><TD CLASS="quote">
Whats your setup? OBD1 motor in a OBD2 car?</TD></TR></TABLE>
correct
most likely going to buy this
http://www.hmotorsonline.com/s...30005
and put it in my 99 DX
correct
Dizzy:
Your DX has a 8 wire connector. On that connector you have a blk.yel wire. On the OBD1 dizzy, it is spilt in two plugs. Just take the blk/yel and connect it to blk.yel on the OBD1 dizzy.
Injectors:
You will need to convert your OBD2 harness to OBD1 style clips OR reuse your old D-series injectors.
IAT:
Extend and splice in OBD1 style plug.
Alt:
Change the alt to a OBD1 style clip or buy a OBD2 alt
Injectors:
IAT:
Alt:
RACEPAK
02-11-2006 09:04 PM
