OBD2 to OBD1
OBD2 to OBD1
If you convert from Obd 2 to obd1. How do you get your car inspected. I am trying to get rid of a cel code 91. I researched and everybody says there is no fuel tank pressure sensor on 96 d16y7's. If not, why am I getting a cel? Can you inspect a OBD2 car with an OBD1 ECU?
Re: OBD2 to OBD1 (JDMJONES)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMJONES »</TD></TR><TR><TD CLASS="quote">If you convert from Obd 2 to obd1. How do you get your car inspected. I am trying to get rid of a cel code 91. I researched and everybody says there is no fuel tank pressure sensor on 96 d16y7's. If not, why am I getting a cel? Can you inspect a OBD2 car with an OBD1 ECU?</TD></TR></TABLE>
OBD2 to OBD1 isnt going to pass inspection here anymore. You've got to hook up to the OBD port in an OBDII car to pass inspection anymore. I don't know how to kill the code 91 though.
Re: OBD2 to OBD1 (Ricey McRicerton)
I tried to wire in a potentiometer tonight. I cant find the sensor. Plus, my honda manual and the info a person that has done it doesn't match. If I knew what color the wires were or where the sensor was I would be straight.
hmmmm. I know in va if theres no check engine lite they dont dig into checking that kind of stuff. I dont know what kind of emission checks they do where your at. If its that bad I would get a fuel tank censor and cut the plug to the harness and then repin it to your car. That should fix the problem.
I have a 96 Del Sol S. d16Y7. I need the colors or pin positions of the fuel tank pressure sensor. I got from another guy that it was D10, D15, and D11. But I don't know how to red the pins.
90Rexx
15
02-06-2010 09:20 PM
FrederickRighteous
03-17-2008 11:27 AM
