OBD2 motor on OBD1 harness?
ok heres the skinny, i have a 2000 gsr motor, in my 95 gsr, theft recovery.
the harness was all cut up and i tried to resolder a new on ein, but.. that didnt happen, sooo.
i have a 95 del sol harness here (dohc vtec) will my motor run with that instead?
i know that there is one plug missing on the pass side shock tower, but its for the Crank Speed Fluctuation Sensor (something i am not running anyway.)
Re: OBD2 motor on OBD1 harness? (2k1_ITR_0736)
a del sol wiring harness is on the right track, but its going to take a lot more. Alot of sensors on a 2000 GSR engine have OBD2 plugs, not to mention the secondaries aren't wired, I think the injectors, alternator, and few other plugs on the car won't match up with your del sol harness.....
You might have to change out a few of your OBD2 sensors for OBD1 sensors....Don't quote me on this, but I believe that is your problem..
Good luck
Good luck
Yea i think scott is on the right track, you may as well do a full OBD-2 to OBD-1 conversion. And get a Skunk 2 GSR manifold, because if you use a OBD-1 harness for a Sol you gonna be eliminating teh 2ndary butterlys. And theres alot of stupid useless **** on the OBD-2 harness. 3 plug vs 4 plug, more emissions controll stuff on the OBD-2 harness.
Re: OBD2 motor on OBD1 harness? (Moe)
oh, btw its not a gsr manifold here is the mod list
1998 B18C1 block
2000 ITR head
2000 ITR intake manifold
1998 ITR transmission with LSD
act stage 4 clutch
aasco 8.8lb flywheel
eagle i beam rods
edyne 11.5:1 pistons
skunk2 stage 2 cams
skunk2 stainless valves
jun Ti valve springs
crower retainers
rc 370cc injectors
aem fuel rail
aem FPR (set at 60 psi)
b&m FP guage
Spoon 70mm throttle body
AEM cam gears
AN-R compact street header
thermal R&D catback (or should i say test pipe back?)
hondata 2b p28
apexi vafc
NOS pro fogger directport wet kit (70 shot)
walbro 255 fuel pump
Autometer ProComp Light A/F guage
Autometer ProComp light Oil pressure guage
skunk2 short shifter
STR cam seals
Autometer Guage Cluster Pod
Stainless Braided Fuel Lines
Stainless Braided Raditor Lines
Stainless Brake lines
Hyper Ground style system (custom by me)
1998 B18C1 block
2000 ITR head
act stage 4 clutch
eagle i beam rods
skunk2 stage 2 cams
crower retainers
rc 370cc injectors
aem fuel rail
b&m FP guage
AEM cam gears
hondata 2b p28
apexi vafc
STR cam seals
greg677
09-10-2016 08:54 AM
