is obd0 to obd1 distributor possible?
is it possible to rewire a distributor to make it from obd0 to obd1, coz' my friend is doing a jdm b16a1 swap on my honda civic hatchback cx,we got everything done the mounts, cable to hydro. conv.,obd1 ecu,double check the connection, ground wires and stuff but my car still wont' start, what can possible be wrong to make my car not run,its trying to start but wont start all the way...can you guys help me out?what should i do? or check for?
Re: is obd0 to obd1 distributor possible? (jvithayapun)
Had the same problem, did the same swap. 1st gen B16A converted to OBD-1 and installed in a 93 EX.
Yes, you need an OBD-1 B-series distributor. The number of teeth inside are different. Use a non-VTEC one and cut off the front lower leg to make it fit and save money. Also, make sure you're using OBD-1 injectors(from your old motor). OBD-0 ones require a resistor box.
Other things that I needed to complete the OBD 0->1 conversion:
Firewall mounted MAP sensor and EVAP purge control solenoid valve
4-wire gray plug O2 sensor
Bseries OBD-1 thermostat housing with temp sensor(mine came from a '92 B18A1 teg)
chipped P28 ECU(this way you don't need a knock sensor like the P72/P30)
For me, as soon as I got the right distributor, it fired right up. You can probably sell your obd-0 one for $100. Good Luck.
VegasInvasion
07-01-2010 10:49 AM
itsJDMyo
02-04-2005 06:18 AM
DA-MAX
05-16-2004 01:44 PM
highvelocitynyc
08-17-2003 10:17 PM
