obd0 to obd1?????
Old 03-20-2004, 01:05 PM
Orangecivic251's Avatar
Default obd0 to obd1?????
is it possible to convert a b18a1 that is obd0 to obd1??? i had a guy offer me 2 b18a1'a and a non v-tec dohc zc motor for 650 (no trannys or ecus) but i wa sjust wondering if it's worth it? i've sen them and they are still in the car they are at this junkyard i found. and didn't know if it could be converted let me knwo if possible and if not a list of things i will need to make it work in my 94 civic dx. sorry for the newbie questions
Old 03-20-2004, 01:24 PM
Default Re: obd0 to obd1????? (OrangeCiviC251)
c'mon guys need answers lol!
Old 03-20-2004, 09:23 PM
TriggerHappy101's Avatar
sorry. Not a clue. Bump for you.
Old 03-20-2004, 09:55 PM
b16aEGcivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OrangeCiviC251 &raquo;</TD></TR><TR><TD CLASS="quote">is it possible to convert a b18a1 that is obd0 to obd1??? i had a guy offer me 2 b18a1'a and a non v-tec dohc zc motor for 650 (no trannys or ecus) but i wa sjust wondering if it's worth it? i've sen them and they are still in the car they are at this junkyard i found. and didn't know if it could be converted let me knwo if possible and if not a list of things i will need to make it work in my 94 civic dx. sorry for the newbie questions</TD></TR></TABLE>
it an be converted to obd1 by switching to obd1 injectors, dizzy, and ecu...also you will have to hook up your MAP sensor by T fitting into a vaccum line and mounting it on the firewall because the obd0 TB does not have a mounting place. I mite have missed a couple minor things but overall that is it....oh and you can use your 94 dx wiring harness on the b18 motor as a deirect swap over...just plug and play....oh also you will need the VSS out of your current motor due to the fact that the older b18s have a cable driven speedo. The tranny I would recomend getting a Hydro to save yourself the trouble....also you will need 94 and B series teg mounts
Old 03-21-2004, 05:57 PM
Default Re: obd0 to obd1????? (b16aEGcivic)
ok i take it that if i took a b18b tb that would eliminate having to attach it to the fire wall correct? and if anydoes knwo if he missed any steps or if anyone knows a write up on it let em know please!!!!!
Old 03-21-2004, 05:58 PM
also not on the wiring harness. will i have to make any corrections to that harness at all?? like where the end of the harness meets the ls ecu will the dx plugs work??? any write up on that would be nice also!
Old 03-21-2004, 06:36 PM
c'mon honda guys talk to me. show me your infinite knowledge!!!!!!!!!!!!!!!!!!!
Old 03-21-2004, 09:06 PM
you will not need to mod your harness at all...also you will want to buy a thermostat housing and fan switch from an obd1 B series because it is defferent I beleive...I know on my b16a I needed to swap it,...also the ecu and harness are all plug and play
Old 03-22-2004, 01:00 PM
ok so now i have all this what would be the benefit of converting it to obd1? i plan on turboing it out shortly after the swap. is it worth the money for a b18a1 block converted to obd-1 in a dx coupe?
Old 03-22-2004, 11:48 PM
any guess?
Old 03-23-2004, 10:49 AM
anything?
sublimeh215
01-29-2010 06:41 AM
Syndacate
14
07-17-2006 04:25 AM
t0eKnEe
17
05-05-2003 08:26 PM
Jon Black
03-12-2003 12:36 PM
Quick Reply: obd0 to obd1?????
