obd0 motor in obd2 car need a little help
JDM B16A ok i no i need to get a obd1 or 2 distributor and injectors what distributor will bolt on my head will a 00 civic si work and i got 00 civic si injectors... now for a ecu its going to have to be obd1 whats a good ecu to get and will i have to have it chiped and tuned
Re: obd0 motor in obd2 car need a little help
If you plan on passing any OBD2 code reading emissions equipment (or planning on using an OBD2 ECU) you will need to add a crank position sensor also.
You can run the pre-obd injectors if you want to. You do not have to get the OBD1/2 injectors. You can run either the OBD1 or OBD2 b-series vtec distributor. If you are going to get the OBD1 ecu chipped, you might as well get a P28 or converted P06.
Seagull Management
CKF trick --> http://technet.ff-squad.com/ckftrick.htm
thats a lot of good info thanks guys. what do you think i should do about the tranny i have calbe now go to a lsd hydro
strictly.business
11-25-2006 09:05 PM
