OBD0 b16a swap into 96 Civic SOHC VTEC ?'s
ok here's my question. I am going to be swapping a first gen obd0 b16a into a 96 sohc vtec civic. Should i buy OBD2 ecu so it plugs into the 96 civic harness and wire it up obd2, or just buy obd1 ecu and jumper and wire up obd1. it already has vtec components wired up so which should i do?? any advice will help. THANKS!!!!!
EDIT: also if i go obd2 can i use the sohc distributor or do i need b series OBDx distributor? |
Re: OBD0 b16a swap into 96 Civic SOHC VTEC ?'s (spcrxracer)
bump
dude....you are soooo up a creek if you are asking these questions!!!!!!!
you have no idea!!!! search.... basically you need to convert the NONOBD engine to obd2....meaning dizzy crank angle obd2 oil pump obd2 tbelt cover obd2 injectors then you'll need a chipped p28 obd2a to obd1 jumper harness do i need to go on?? pay someone who knows what they are doing!! |
