o2 simulator?
o2 simulator?
anyone know where i can get an o2 simulator i have a 00 SI and i looked on JEGS and Summits Website and couldnt find one i found them on ebay but i dunno if i trust them..any info?
Re: o2 simulator?
http://www.o2simulator.com/
i have heard good things about this company
Re: o2 simulator?
WHy do you need a simulator? 2nd O2 can be tricked into thinking it's working and even a old, nearly wore out one would be fine. $5 at a pick and pull. Primary can be disabled in Crome, Hondata, ECTune...
318 Curves, 11 miles
Re: o2 simulator?
If you mean secondary, I've got schematics somewhere in my garage on how to wire up something that will trick the ECU into thinking you've got a good secondary and a good cat. Good for getting rid of the secondary O2 code, and there are really no adverse effects since the secondary doesn't really do anything but test your cat efficiency.
I'll have to dig around when I get home.
Re: o2 simulator?
because i dont have a cat on my car its just a straight pipe i have 2 o2 sensors and my car keeps throwing a CEL code p0420..i talked to a few shops and they told me the same thing get an o2 simulator
I'm not Rick!
Re: o2 simulator?
well it sounds like yoru 2 o2 sensors are getting too much flow...get those o2 extnesions first and try those from. ebay or autozone or you can act like baller and pay 6x as much for them at www.passwordjdm.com
Re: o2 simulator?
there are different plug endings on the universal ones anyone know what plug i would need for this to work?
Man U FTW
Re: o2 simulator?
If you can make the 2nd o2 see heat and clean air, it will stop throwing a CEL. It's ghetto indeed, but if you can heat wrap it to the outside of your exhaust pipe where it will register radiant heat from the pipe while breathing clean air, all your problems should disappear. There are also easy schematics available if you want to wire in a resistor into the circuit that returns a false-positive signal to the ECU. Either of those options should work just fine...
Re: o2 simulator?
dohc_ms55112
02-18-2006 11:19 AM
