O2 sensor wiring!need wiring gurus!
I have to wire up my o2 sensor manually because my engine harness doesn't have a plug.does any one know where the O2 sensor wires are on the ecu shock tower.btw I have a auto ls engine harness.I need to wire up all 4 wires.
Re: O2 sensor wiring!need wiring gurus!
Sorry bro, I haven't been around for a while...
Here is what you need though. The O2 sensor runs through the C212 connector (passenger side shock tower) to the ECU. The pinouts on page 3 are when viewing the clip from the wire side with the locking clip facing up. I hope this helps.
yes page 1 and 2 help alot.yellow/black wire runs to the main relay,orange/black goes to the the a6 teminal on the ecu.am i reading it right so far?
i dont get how to read these shock tower plug codes:c111 c212
thanks a bunch for the upload man!!
Yeah again sorry it took me so long to get this to you. I might have some other helpful schematic stuff to upload later. As for connector codes, C111 is the plug on the engine harness that attaches to the O2 sensor. C212 is the engine harness to chasis harness connection on the passenger side shock tower mount. Just look at the clips for some open spots, and use pig tails cut from other under hood Honda clips. Reason being is because they have that waterproofing rubber plug and you want to wire it in legit. Also be sure to solder and heatshrink your connections, don't use crimp connectors and electrical tape as they may increase the resistance in the circuit. Which could cause the sensor signal to be modified as it travels to the ecu... Well modified isn't the proper word for it, signal strength can be reduced to/from the sensor.
Don't worry about it man atleast u took the time out to help me out!I figured out where the connections for the 3,4 wire but what about the green and white wire.I beleave they are grounds but do they also go through the the passenger shock tower plug c212 or are they just grounded on the engine?
I just hit a jackpot!!I found my old hynes repair manual!!it has the complete wiring diagram!ill post it later so everyone else running into similar prob can use it.
White-d14 terminal
Green/white-intake air temp sensor
Yel/blk-pin 6 on connector c125(plug in the driverside shock tower with all yel/blk wires)
Org/blk- a6 terminal on ecu
White-d14 terminal
There is a prob like always haha.I looked at the harness closely and I found cut wires so dug in a little bit and they are just a completely different color that the ones I posted above.this is a later model integra motor.the four wires are:grey,yel/blk,green/blk,blk/white.so my question is which one connects to which wire on the o2 sensor?
Just so someonebafter me can use this.
For b18b1 engine
White-grey
Yel/blk-yel/blk
Grn/white-grn/blue
Orng/blk-blk/white
For b18b1 engine
White-grey
Yel/blk-yel/blk
Grn/white-grn/blue
Orng/blk-blk/white
primeredbeast
08-16-2005 11:10 AM
