o2 sensor question!
Old 11-30-2012, 08:58 PM
ewilliams1990's Avatar
Default o2 sensor question!
I have a 98 honda civic cx with d16y7. I need to replace my secondary o2 sensor. Can someone please give me a link or tell me whats a good one to get. Someone said something about like a denso one from amazon running like 40ish bucks. And. Is the primary o2 sensor the same as the secondary? Are they interchangeable? thanks for the help guys!
Old 12-01-2012, 06:48 AM
Default Re: o2 sensor question!
128views and nothing?
Old 12-01-2012, 06:52 AM
jbpnoman's Avatar
NTK/NGK makes the OEM unit, so I would get one of those first. Denso is a good fallback plan.
They are interchangeable.
Old 12-01-2012, 01:54 PM
civicguy395's Avatar
the main one is 4 wire and the secondary is 3 wire
Old 12-01-2012, 05:20 PM
Technical Hero
HondaPartsHero's Avatar
Amazon or rockauto.com for the denso
Old 12-01-2012, 05:50 PM
jbpnoman's Avatar
Hmm, maybe I'm crazy. I could have sworn I just put my backup O2 sensor, which used to be my secondary, in place of my oil soaked primary. Maybe I just had an extra primary laying around.
Old 12-01-2012, 07:20 PM
Now im confused! Can anyone give me a direct link on amazon to buy a denso secondary sensor? the one near the cat converter. thanks again
Old 12-01-2012, 07:23 PM
jbpnoman's Avatar
"Near" doesn't help. They're both near the cat. One's above, and one's below. The secondary is below. I'm just making this clear to make sure you don't accidentally order the wrong part, so don't take it as an insult to your intelligence.
36532-P2E-A01
There's your part number, straight from Honda. You should be able to easily find one from there.
Old 12-01-2012, 07:54 PM
Well, primary is on the manifold, no? and secondary is near/on the cat? and thanks for the part number. I need the o2 sensor II. I have a p0135 code. o2 sensor II heater circuit.
Old 12-01-2012, 07:59 PM
jbpnoman's Avatar
Primary is on the manifold, above (and near) the cat. Secondary is below (and near) the cat. I just want to make sure we're talking about the same part so I don't send you off to buy the wrong thing.
Sounds like we're on the same page, though. That part number should lead you to what you need.
astroxtc
12-13-2006 12:57 PM
rdeezy25
05-16-2005 12:31 PM
aDnOhCiViCiS98
04-23-2005 04:46 PM
Green94GSR
03-01-2004 02:05 PM
LsTurbo91
10-08-2001 09:20 PM
Quick Reply: o2 sensor question!
