O2 SENSOR HELP PLZ!
Old 02-21-2005, 06:02 PM
B20runner's Avatar
Default O2 SENSOR HELP PLZ!
yeah how do u find out which sensor is bad?
im guessing the front sensor is the one u can see by the manifold and rear is the one u cant?
overall obd result: fail
fault code result: fail
fault codes:p0171,p0141,
ddescription:-
p0141:O2 sensor heater circuit malfunction (bank 11 sensor2)
p0171:system too lean (bank 11)
thx
Old 02-21-2005, 06:12 PM
Turbo_y8's Avatar
Default Re: O2 SENSOR HELP PLZ! (B20runner)
Is It obd I or obdII. Go to autozone and have em read your ECU, if you failed most likely your check engine light is on, and a code will tell you promary or secondary, somehting of the short, or oull them out and look at em, they should be white, but if your failed emissions it not cause of 02 senors your cat might be toast or a vaccum or EGr (if you have one)
Old 02-21-2005, 06:14 PM
B20runner's Avatar
Default Re: O2 SENSOR HELP PLZ! (Honda_project98)
its obd2 acura ls ecu 96-99 on a b20b
Old 02-21-2005, 07:02 PM
95dxhatch's Avatar
the code p0141 when it says bank11 sensor 2 it means just that. the 2nd sensor is the one that's bad.
Kentagious
Honda Civic (2006 - 2015)
09-22-2016 06:41 AM
crx2hatch
02-10-2011 06:30 AM
bma1818
12
02-03-2007 10:45 AM
93FastLs
12-15-2004 03:48 AM
Lewie
06-29-2004 09:11 AM
Quick Reply: O2 SENSOR HELP PLZ!
