o2 sensor ?
o2 sensor ?
hers my problem im gettn shitty gas miles I got new dizzy sparkplugs,wires, and motor was rebuilt 2 months ago. before I rebuilt the motor my rings were shot blowing oil out the exhaust... my ? could the o2 sensor b bad and not b throwing a code? car seems to run fine except for the shitty gas miles...BTW im gettn 400 kilometers a tank,so its alot less in mph....anyone have some feedback?
Re: o2 sensor ? (hondachris1994)
usually it will throw a code. mine does. i've driven without the primary and without the secondary and gas mileage didn't change. i'm still confused on why my car doesn't seem to care whether or not i have an o2 sensor. check to see what your plugs look like. you could be runnning rich or maybe bad timing?
a lazy o2 will not throw a code and it could effect your gas milage. check your timing it should be at 15 degrees BTDC. and a clogged air filter will give you shitty gas milage too
white could also be over advanced ignition timing. how much were you getting on a tank before? i usually get about 460. mix of city and highway.
Re: o2 sensor ? (fmrprojects)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fmrprojects »</TD></TR><TR><TD CLASS="quote">. check your timing it should be at 15 degrees BTDC. and a clogged air filter will give you shitty gas milage too</TD></TR></TABLE>I got adjustable cam gears and I cant really tell the degrees,and the air filter is brand new
Re: o2 sensor ? (Civicse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Civicse »</TD></TR><TR><TD CLASS="quote">he's referring to ignition timing not cam timing. look on the crank pully</TD></TR></TABLE>its rt on
b18LS
07-23-2007 10:14 PM
HipHop Head
01-08-2005 02:03 PM
