O2 senors
Don't cut the leads on the sensors themselves. Only mess with the harness side, and make sure any connections you make are soldered. Personally I recommend not cutting wires, but opening up the conduit on the harness and pull the O2 connectors over to where you need them, then tape it back up. you might have to pull the wires out of the connector one at a time to get them through the tangled mess to where you want them, then reinsert them into the plug...
interruptions in the continuity of the wires can change the voltage that reaches the ecu, which can give false readings so it's important to mod it right.
Re: (civicguy1984)
http://www.casperselectronics.com
And just for clarification, it's Caspers Electronics. casperelectronics.com is some guys website where he make musical instruments from old kids toys.
Re: (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">cut the 02 sensor wires in the middle. get 1.5ft or whatever a new wire the same gauge. solder it in. damn that was hard </TD></TR></TABLE>
btw don't say "oh that won't work, my momma said it'll mess with the voltage readings" b/c i've done it, it works awesome
supermansdx
09-26-2009 11:04 PM
jbbauer7
11-23-2003 10:46 PM
Art Vandeleigh
03-29-2003 09:56 PM
