Nut on the axle
Nut on the axle
Trying to pull the motor from old car and come across the nuts on the end of the axle. It looks like they pinched it or something but it is a bitch to get off . Any ideas?
Solbros Owns Me
Re: Nut on the axle (Nobosswanted)
unstake it....
or, use a lot of force and it will come off. I've never had to unstake one before...just lift up really hard on the breaker bar and the pinched in part bend out
H-T White Ops
undo the crushed in thing on the nut, get a big *** 1/2" or 3/4" breaker bar, right size socket, about a 4' long pipe, some big ************ and have him jump on the pipe to break it loose. I'm just saying the 1/2" thing because that's what I used to get mine on the prelude off. Didn't break.
But if you're worried about breaking it, go to Sears and buy craftsman stuff. It breaks, no biggie. They'll give you a new one.
Will try, do I need to put the wheel on. The whole assy spins when I try to turn it. I am supposed to have LSD trany(TYPE-R), but one of my wheels spin when the car is in gear.
Re: Nut on the axle (FrostySol)
break the nut loose on the ground. use a regular screwdriver and a hammer and bang the kink in the nut out. then use a big wratchet- at least 1/2 drive and a breaker bar(i use a 3 foot piece of pipe that i put over the end of the wratchet) spray it with a lil bit of pb blaster and step on the breaker bar- **** comes right off ive done 5 axles in the past 3 months- and that proceedure works for me every time
I've quit using this account
if you have the car up off the ground, you can put a screwdriver throught the caliper and into the rotor to stop it from ratating.
get a big *** breaker bar, and torque on it.
you can also try to tighten ity alittle to break it loose.
hope that helps
hope that helps
Re: (llewsirc)
bah, just get a screw driver and undent/notch/bent the area on the nut that keeps it from coming off. and smack it with a hammer, and impact it off.
Re: (doublejz)
I had to leave the car on the ground, ebrake up, and put bricks in front of the front tires. 4 ft gas pipe on a 1/2 breaker bar got it off we my friend and I hung from the bar
Re: (DaX)
Unstake it with some type of chisel. After that the best option is an impact wrench, don't have one? Doesn't matter whethet the car is on or off the ground, or if the car has a wheel on or not, put the car in gear have your buddy slam the break and jump on the breaker bar to pop it loose. For the breaker bar I used the end of a car jack pole and slipped a (Craftsman ) ratchet into it. Be careful cause things may break before the actual nut does. Been there, done that, go tthe t-shirt.. was a bitch too
Modified by djurbang at 9:43 PM 1/17/2004
sidious141
47
01-12-2005 11:02 AM
elmalouno
06-02-2003 04:29 PM
