nrg harness bar help
alright well im pretty confused. my bar came in and it came with a bag full of nuts and bolts and spacers...dont i use the bolts that are already there? is there any type of write up for a nrg harness bar install? i tried google and searched on here with no luck
http://www.weaksauceparts.com/store/...at=1894&page=1
for 96-00 hatchback
for 96-00 hatchback
Re: nrg harness bar help
It's a shim to fit kind of thing. Once you start installing it you'll see that some bolts only go in one place. I installed mine by trial and error.
did you pre-measure the pillar widths before ordering? i know it comes with a make model and year, but it is very general and even states pre measure before ordering to ensure you get the correct one.
He has the right one. Because there's 1 inch on each side use a long bolt and the thick washers that came with it.
Here's the order
Bolt - Bar - thick washers (several) - chassis hole
I== ... () ... OOOO ... [O]
Here's the order
There's 1 or 2 washers before the stock seatbelt bracket. This way it can still rotate. So, it's close to the plastic, but barely scraping.
GSRCRXsi
34
07-29-2011 02:26 AM
