Not going in Reverse, and sometimes 2nd and 4th. Help..
Old 07-04-2008, 06:48 AM
91EF_Si's Avatar
Default Not going in Reverse, and sometimes 2nd and 4th. Help..
I just bought the car, and was told they swap the motor/trans/linkage from a 98 coupe(everything was working fine). And when they put it in the 94 coupe I bought, Reverse doesn't work. Can it be the linkage? Because 2nd gears goes in an angle(towards 4th), 4th gear also has an angle(towards R), and reverse just doens't go in. 1st, 3rd, and 5h go in perfect. Please help.
It's a 94 coupe with b16swap, tranny, and new clutch/flywheel/throw out bearing.
Old 07-04-2008, 07:53 AM
JDMPHILEP91's Avatar
Default Re: Not going in Reverse, and sometimes 2nd and 4th. Help.. (91EF_Si)
what kind of tranny do you have?
Old 07-04-2008, 07:57 AM
91EF_Si's Avatar
Default Re: Not going in Reverse, and sometimes 2nd and 4th. Help.. (JDMPHILEP91)
I was told 99 si b16 hydro, but looks to be like jdm b16 or gsr.
Old 07-04-2008, 08:06 AM
jdmphilep's Avatar
have you tried checking the linkage? and do you have a short shifter?
Old 07-04-2008, 09:45 AM
91EF_Si's Avatar
I checked the linkage, and its not rubbing against anything. It does have a b&m short shifter.
Old 07-04-2008, 08:30 PM
V-tecman37's Avatar
I was having a similiar problem with my 2000 LX that was an auto to manual swap. After taking a look underneath the car I found that one of the two bolts that holds the rubber piece that holds the shift linkage to the car was missing. I had never tightened the two bolts after installing the shift linkage. After replacing the missing bolt and tightening the remaining one my shift linkage actually felt crisper than before. So check the shift linkage underneath the car.
Old 07-04-2008, 09:47 PM
91EF_Si's Avatar
Default Re: Not going in Reverse, and sometimes 2nd and 4th. Help.. (V-tecman37)
Yea both bolts are there and tight.
Old 07-04-2008, 09:49 PM
EkFG's Avatar
shot tranny. wrong linkage/
bowdown201
01-08-2009 10:19 AM
skUnK2jdm
11
12-13-2008 11:43 PM
RMX_EF9
37
06-18-2007 02:20 PM
naptownrex
08-20-2006 10:29 AM
Bartman201
10-03-2005 11:09 AM
Quick Reply: Not going in Reverse, and sometimes 2nd and 4th. Help..
