not enough oil?
Re: not enough oil?
why not just put the right amount in like to the 2nd dot. i just dnt understand really why u posted this.you should know how to check ur oil and where it should be but since you asked i assume you dont know. as long as it doesnt go below the last dot you are good i guess i never let mine get that low tho
Re: not enough oil?
So basically its between the 2 dots on the stick?
Thats not to low. Technically when it gets to the bottom dot or below you are not running at the correct oil level. However as shoklid said..I don't under stand why you don't just top it off to the top dot??
Re: not enough oil?
i dont wanna mix old oil with new i usually do my oil changes every 1k miles, so i checked the level yesterday and saw that it was inbetween the dots, just wanted to make sure that it wasnt a big issue driving the car like that
Re: not enough oil?
wow ok why do you change it that much. thats overkill. and also mixing old oil an new oil whats wrong with that. id rather do that than run my oil level down. and y is your car loosing that much oil my goodness not 1000 miles and its low, sounds like u gotta prob on ur hands
Re: not enough oil?
Re: not enough oil?
oh so your doin the 1k change cause u dnt drive it much ok that would make sense. it didnt register to me that u might not drive it much. i wasnt bashing on you at all by any means i just didnt get it. so with that said i think you are doin the right thing i guess
Re: not enough oil?
are you checking it once the car is warm and and a couple minutes after you shut it off. because that will make it go up a little bit since the oil is getting a little thinner
Re: not enough oil?
and mixing oils isn't going to hurt anything as long as you put in the same oil. Use synt if you put synt in it or conventional if thats what you use and you will have no problems
Re: not enough oil?
i know it wont hurt anything but its like adding new coke to a cup that has 1/2 cup of flat coke
Re: not enough oil?
Its easier to just quote what that person said and then respond under it. That way they know exactly who your talking to.
And that analogie was great..haha.
Shoklid, LOL on the ^^^, I saw a post I think it was yesterday and someone did that and I think it might have been Rick_Rabies(not sure)responded and was like "what the hell is ^^^..is that like a JDM cuss word"
It was funny you mentioned the arrow deals when I just read that yesterday.
Re: not enough oil?
Re: not enough oil?
