Nosey Suspension
Nosey Suspension
I have a 95 ex coupe. I did some work to the Suspension. I change it with some Tein springs/ tokico Hps. than I add Front and rear lower and upper strut and tie bars. After I went with some Poly Bushing upgrades.
I’ve done all the ones in the Control arms but haven’t finished the JOb. Sit missing the steering wheel bushing, bump stops and the front upper control arm pivot bushing. But ever since I did the Bushing Job my civic had been making Noise in the rear. I can’t figure out where it is coming from. I checked to see if there was any loosen bolts and I didn’t see anything.
Anybody else have this problem?
Re: Nosey Suspension (Glai1628)
First of all you gotta tell that nosey suspension to mind it's own damn business . Ok now that I got the ******* side out, check your LCA's, they may be loose.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Glai1628 »</TD></TR><TR><TD CLASS="quote"> After I went with some Poly Bushing upgrades.
What kind of noise is it? If it's squeaking, this could be the cause. You should lube bushings up with marine grease or the like before installing. Poly is a noisy material.
wreckedmyteg
10-31-2004 08:17 PM
