noob question about motor swap
once i drop in a gsr motor into my civic lx.. do i need to change out my guage since my redline is different or can i use the stock one that came in my civic???? i no its a dumb question but just need to no haha
Re: noob question about motor swap (epak)
You should be able to use ur old one but the redline might be different so if ur old one tops out at 7k then u wont be able to see ur rpm
please only post one topic about the same exact subject..
https://honda-tech.com/zerothread/1713260
Just keep that topic, let this one die, you can keep the guage cluster, your ECU is probablly the reason, it has nothing to do with your guage cluster, either the ECU, wiring is wrong, or a sensor is not reading what it should (like the oil press. sens)
phoenix_iii
10-06-2010 05:39 PM
