Non starting problem
Ok I decided to try and start the honda 2nite and nothing........
So I decided to try cranking it at the starter and it fired right up.....
I can turn my key and I hear the fuel pump kicking in.
Try to crank it with the key....Nothing...No clicky clicky....
Checked all my grounds.....I think...Ran a wire direct from the battery to the starter to make sure I had a good ground....Nothing..
I thought maybe it had to do with the wires on the clutch pedal..... Why are there 2 plugs on the clutch pedal?
Thank you
E.Honda
Thank you
E.Honda
