Noisy timing belt area (video)
Just discovered this noise a couple hours ago, since then I've been trying to figure out the source but I have no clue...
I'm thinking water pump or the tensioner is going bad?
D16z6, it's cammed so it is a little noisy.
I can hear it more with timing belt cover off and it's more audible at idle.
http://www.youtube.com/watch?v=WTuQ1gCmfI8
Bad quality I know, had to use my phone.
If I put my stethoscope in these areas (marked in red) the sound is most audible.
I searched all over for anything loose, or signs of damage but nothing. I went over the timing belt as well looking for any wear but it all looks good, has somewhere around 75k miles on it, I don't know if the tensioner was changed as well since the car was not mine at the time.
Re: Noisy timing belt area (video)
That lower cover for the timing belt could be cracked right by the bolt hole and that plastic will squeak with engine vibration. I had that problem.
How new is the water pump ? It's right behind that area.
No cracks that I can see.
I'm not sure of it's age, I know it's got at least 75k miles on it. I know leaking is a sign of it going bad, but what about noise? Do they tend to make a noise before going out?
My friends leaked all over the place in her Civic, but it never made a sound when it went bad.
Thoughts anyone? Should I drive it? Cause I really depend on this car every week, I'm not sure if I should hang up the key or not until the weekend when I can get a better look at it.
Alright, nearly a month later I finally found the time to do the tensioner and timing belt. Replaced those but noise is exactly the same, I don't know what it is. I didn't replace the water pump but I spun the bearing/whatever you want to call it and it was dead quiet.
Still don't know what's causing the knocking noise, it's definitely more pronounced at 500-600 rpms and gradually disappears as rpm rises. Like I said it is cammed and has been since late '10 but never used to make this loud knocking noise.
RedRyda
07-28-2004 06:20 PM
