noise Coming from head 99 Si
Ok There is a noise coming from my head it's sounds kinda of like Valve Chatter but only at idle and it's the same sound the head is stok except cam gears. Block is b16 obd1 with knife edge crank, 9 to 1 pistons,bored a little , H- Beam rods, AZ blocked deck , ARP head studs. I had alot of valve chatter before I put the block in when I had the block put in I had them also adjust valves now I have this noise anyone have an idea on this?
My JDM B16A does the same....I had my valves adjusted and it didn't change it, so..... Bump for an answer. I've heard it could be LMA's, injector tick, and a few other things.
Re: (CO$T)
Yeah my JDM 2nd gen b16a does it too, only at idle!!! I remember when I did my D16 mini me and the heead had a ticking sound also, so I did a valve adjustment, and it was still the same so i went to a shop, and I watched them do it, and it still sounded the same. So I don't Know!!! But I remember reading some post and someone said that honda motors tick alittle! So I don't know what to tell you! And my internals are stock.
Re: (marcosh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marcosh »</TD></TR><TR><TD CLASS="quote">Should be your injectors</TD></TR></TABLE>
i dont think thats the problem.
Re: (marcosh)
most people don't realize that there injector's do make a clicking noise , they think its there valves....lol not saying it couldn't be something else thre always a chance .. but if u had ur valves adjusted chances are its not them
lee - why does your cousins pcv valve - that sounds more like its truelly comming from the valve train maybe even your lmas like in his situation!
Re: (b204dr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b204dr »</TD></TR><TR><TD CLASS="quote">lee - why does your cousins pcv valve - that sounds more like its truelly comming from the valve train maybe even your lmas like in his situation! </TD></TR></TABLE>
I don't know...just a thought, from past problems I have notice that a sticky pcv will cause a tick also.
Nick97hatch
12-19-2009 03:51 PM
