no vtec hitting
Location: down the street,bythe river in the van, co, united states
no vtec hitting
so i got a ctr swap on my em1 and for some reason at first it would hit vtec good but i had an fuel leak and it lit on fire so i replaced the harness and now my vtec on hits sumtimes or like wen ever it wants to and it sucks any ideas on wat to do to fix it? im running a mugen chipped ecu and eveerything is connected only thing is that the knock sensor melted so that aint plugged in but everything else i connected and ideas would be helpful
Modified by 99hondacura at 9:00 AM 2/14/2007
Re: no vtec hitting (95vtecsrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vtecsrus »</TD></TR><TR><TD CLASS="quote">you left your crank sensor unplugged?? hmmm better get that fixed...thats very vital for everything else to work properly</TD></TR></TABLE>
seriously
seriously
Re: (99hondacura)
your knock sensor shouldnt have anything to do with your vtec not working...make sure you double/triple check all your wiring..back to the ecu, if there has been a fire...its also possible you didnt repair your wires good enough
yea i got a totally new harness that wasnt cut or nothing and it only hits vtec sometimes lik only wen it wants to
yup cleaned the vtec solenoid yesterday and yea it getting the right oil pressure everything is good wat else you guys think is wrong wit it
1 Post
Re: (95vtecsrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95vtecsrus »</TD></TR><TR><TD CLASS="quote">your knock sensor shouldnt have anything to do with your vtec not working...make sure you double/triple check all your wiring..back to the ecu, if there has been a fire...its also possible you didnt repair your wires good enough</TD></TR></TABLE>
Please don't speak what you don't know. If your knock sensor is broken/ not there VTEC will not engage, unless you are running a chipped ecu, with that sensor disabled. Have you checked your oil level also?
you stated you had a fire????
if you had a fire and some of the wiring melted....some of the copper strands on the inside of the wires might'veeither touched each other or grounded out maybe causing something to fry in your ECU. I'd say pull out your ecu...pull the 4 or 5 screws that hold the outer casing on and take a look inside. Actually if it is fried you should be able to smell something burnt from the ECU before you see anything. I'm not saying this is def. it but, it's a possibility.
Re: (Malakai)
ok, if u own a honda or integra u should learn somethin bout them before u give advice. 95vtec did u seriously say that the knock sensor has nuttin to do wit y ur vtec aint hittin or not! come on, u gotta be kiddin me, my6 yr old nephew knows that. point of sarcasim, dont give advice when u dont know wat u talkin bout. if knock sensor aint hooked up ur ecu cant read it, if ecu cant read it then no vtec. hook it up u will be aiight
Re: (civicgsr12)
i agree. shouldnt try to give advice on stuff you dont know about. and yes the knock sensor not being plugged in or broke will cause the vtec to NOT engage.
