no throttle response
hey guys i have no throllte response over 1/2 throttle and and i have to keep it to the floor for it to stay running have no codes.i have no idea what else it could be.timing is good i set timing and it got better.i cleaned plugs and gapped them.
Re: no throttle response (SLO Sol)
my dad checked the compression and said it was fine.i mean it runs and then its really choppy almost like a misfire or running on like 3 cylenders.put there all fireing i checked for spark on all the plugs and checked all the injectors and there all working.but ill have it idleing for a minute or to and it will shut off and when i have it to the floor it idles at like 800 rpms.but if i move the throttle on the t/b it wont go more then 1/2 way or it will bog out like its getting to much or to little fuel
i just put a head gasket on it.and then this started happening.i didnt disconnect anything i had the cherry picker there and just lifted the head cleaned the gasket off it and the block cleaned the chambers and put it back together.i can stick a screw driver in the chamber and its dry so i know i didnt blow it again or have a cracked or warped head
Re: no throttle response (93baggedcivic)
wait you just put a headgasket? are you sure that the timing is right? you can try and check the tps by getting a volt meter and checking it at closed throttle and WOT.
.9 closed 5.0 wot
.9 closed 5.0 wot
Vtec04
11-14-2016 05:48 AM
fakeownzjoo
09-21-2006 04:31 PM
piscorpio
12
04-28-2003 05:10 AM
