No start after head R&R. No spark/No injector pulse
Old 12-26-2016, 11:00 AM
D16potato's Avatar
Default No start after head R&R. No spark/No injector pulse
Hey guys hope everyone had a merry christmas.
Now unfortunately this no start problems happens too often to myself and others. Here's a little background and also what i have done.
99 civic ex 5 speed bone stock
Head was making loud tapping noises, pulled the head off and the keyway from the cam gear had broken a chunk off the end of the camshaft so the camgear had a few degrees of play in it...
Swapped in a known working head. re-installed my known working distributor redid the timing belt. and no start. i had fuel and i had spark, so i checked timing and wasnt sure if cam was 180 off so i redid the timing and sure enough it was spot on the first time. Only changes done were redoing the timing belt and now there is no spark or fuel pulse.
My problem is showing symptoms of a bad ground. G101 is on tight hasnt been removed or messed with before or after head replacement.I have NO SPARK and NO INJECTOR PULSE.
When key is turned once, relay clicks. with Key turned on but engine off pump primes and then clicks again when done priming.
I have confirmed no spark across all four wires.
Hooked up a noid light to injector plugs and injectors are not firing.
I checked my CKF sensor and pin 1 and 3 have 2.2ohms which is within spec.
Fuse 9 and 13 installed have power to both terminals.
Fuel pump primes and there is pressure at the rail
Distributor was known to be working hours before. ECU works fine
Any help is greatly appreciated, this one has me stumped.
Old 12-27-2016, 11:03 AM
D16potato's Avatar
Default Re: No start after head R&R. No spark/No injector pulse
Bump. I have a multimeter and test light ready at my disposal.
Old 12-27-2016, 03:50 PM
D16potato's Avatar
bump. searched again and went thru a post with the same symptoms. no spark no injector pulse and the fix was a new distributor.
went to the junkyard pulled a obd2a distributor, wired it for obd2b and had a helper crank it and unfortunately i did not have any injector pulse. I did however get spark (only) to #2 cylinder but after trying again the spark dissapeared .
Im curious why swapping the distributor would only give me spark to #2 and not all of them. but spark is gone now...
Old 12-28-2016, 02:57 PM
D16potato's Avatar
Tried a spare relay off one of my other civics. No go. Still no spark or injector pulse.
bump..
Old 12-28-2016, 02:58 PM
D16potato's Avatar
Dont know why since my relay already was working, but im using whatever options i have, using older threads although not really progressing
Old 12-30-2016, 02:00 PM
D16potato's Avatar
bump anyone?
Old 12-30-2016, 02:05 PM
D16potato's Avatar
Paypal $50 to whoever helps me solve the issue
Old 12-30-2016, 03:27 PM
D16potato's Avatar
aside from swapping out another ECU, all points are leading me to test out another Crank posi sensor.. will get back to this and update.
would make sense as i just redid the timing belt, its possible it could've been damaged
Old 12-31-2016, 07:24 AM
talks to himself
CX-Adam's Avatar
Trace the Yellow with the black tracer wire from the injectors back to the cabin harness to find the interruption.
I had a similar problem. There's a plug on the driver side strut tower that connects the engine harness to the cabin harness. One of the pins had back it self out of the plug just enough to interrupt the connection.
Originally Posted by CX-Adam
Old 12-31-2016, 07:28 AM
mk378's Avatar
There's also a splice inside the engine harness where the 4 yellow and black wires from the injectors merge into one. These splices can corrode.
Old 12-31-2016, 07:50 AM
D16potato's Avatar
thanks fellas, would i have to unravel the harness or is it easily accessible. I will also check to see if the pin had back out. Im at work currently but get off at 6. I appreciate the help.
Old 12-31-2016, 08:06 AM
mk378's Avatar
Test for power at the big plug where the engine harness meets the car harness. If you have it there but not at the injectors, then the problem would be in the engine harness. If it is that, I'd remove the whole harness from the engine to repair or replace.
Old 12-31-2016, 08:34 AM
D16potato's Avatar
​​​​​​​that would be the big plug by the master cylinder? And that would be the blk with yellow stripe?
Old 01-01-2017, 09:23 AM
D16potato's Avatar
happy new years everyone.
A little late but i checked for power at the black with yellow stripe wire by the driver side connector.. I have power on both ends before and after plug. does that mean i should be getting injector pulse?
EDIT: I also have voltage at the power on the 2p connector for the injectors
Old 01-02-2017, 03:58 PM
D16potato's Avatar
bump. looking for any more suggestions before i bite the bullet and have an electrical tech look at it.
Old 01-03-2017, 09:06 AM
talks to himself
CX-Adam's Avatar
No. The ECU sends a ground signal to the colored wires of the injectors. The injectors always have a power signal via the yellow/black wire. So, the "pulse" you're talking about is actually a ground pulse. I think the ground wires go to the plugs on the passenger side tower. Check for continuity.
Old 01-03-2017, 08:59 PM
Former User's Avatar
1) Crank engine for 30 seconds, and then check for CEL codes. Post any codes you retrieve.
2) Do the test below:
  • Turn key off.
  • Unplug ECU connector B.
  • Do you measure continuity to body ground at pins B2 and B10 in the unplugged connector?
civicsichik
17
04-07-2010 07:44 PM
SinglecamMitch
06-05-2008 09:18 AM
217sportcompacts
09-06-2006 03:08 AM
civicdust
11-16-2005 12:35 PM
CelicaGT-S
08-12-2005 03:54 PM
Quick Reply: No start after head R&R. No spark/No injector pulse
