no spark in Wires (no signal from dizzy) and Injectors have no signal
well this is my problem my car started with me giving it throttle and it would turn on then the car would try to idle and shut off we tried it agen and it would do the same thing after the third time it wouldnt start i took it to a near by mechanic he said no signal from the ECM going to the Injectors and no spark from the spark plugs (had to push car 5 blocks up hills with oncoming TRAFFIC) and well this is day 2 of this problem any SUggestiong ANY answers to this PROBLEM no injector SIGNAL and no spark from Spark plug wires HELP ASAP !!!!!
Re: no spark in Wires (no signal from dizzy) and Injectors have no signal (Nicaraguense13)
Check out my thread, I'm had similar trouble.
https://honda-tech.com/zerothread/1635498
Check out your ECU fuse in the engine bay fuse panel, its a 15 amp mini-fuse.
Let me know how you make out, maybe we can help each other.
I also posted in this topic, similar situation.
https://honda-tech.com/zerothread?id=1637374
95turbohatch
24
04-07-2004 08:07 PM
