NO SPARK NO FUEL 92 civic si GSR swap.....
ok my car ran PERFECT.... I wanted to put in a FUEL CUT OFF SWITCH...
So i wired it in and checked it.... everything worked fine.
Now i forgot to unhook BATTERY while i was finishing the
install (hideing the switch). I never saw a spark from touching
wires but that doesent mean it didnt happen.... What would
it BLOW or FRY ?
After i was done i tryed to start it and its NOT primeing the FUEL PUMP
and im getting no SPARK ? ? ?
Things ive checked.
MAIN RELAY
ALL FUSES
I HARD WIRED THE FUEL PUMP AND IT KICKED ON
SWAPED ECU'S
REMOVED THE SWITCH AND PUT IT BACK TO STOCK
Like i said the car was perfect before all i was doing was adding a switch
to help keep the thieves from stealing my ish.
it BLOW or FRY ?
Things ive checked.
MAIN RELAY
ALL FUSES
SWAPED ECU'S
Re: (civic95hbvtec)
how do you know you didnt short out the main relay? did you replace it with a known good relay? i would check the fuel pump fuse and the main relay
how do you know you didnt short out the main relay? did you replace it with a known good relay? i would check the fuel pump fuse and the main relay i argree with him too
wtfisvtec??
36
08-16-2023 07:31 AM
LoveesHondas92
03-19-2016 04:13 PM
rsanders21
10-30-2007 10:22 PM
Agent Daimon
02-09-2003 01:06 PM
