No SOL go to waste.
Old 03-10-2008, 06:09 PM
Minh826's Avatar
Default No SOL go to waste.
Just wanted to share what i've been working on my newly aquired 95 Del Sol Si. i got the car with a blown up motor, melted #1 piston, and a mess of parts. I traded my 91 EF sedan for the sol. The car used to have a rigged up turbo kit, and didn't last long. So i'm starting fresh.
D16z6
Vitara YCP piston 75.5mm
NPR Rings
ACL Race Serie bearings
Tuner toys rods
ARP rods bolt
ARP head studs
Golden Eagle block guard
TT 550cc injectors
Bored and knotched z6 block
Stock z6 head for now
Undecided on turbo kit (any suggestions?)
I will update with futher mods, Right now it's N/A for the break in period...yay
Here's some pics, comments welcome.
Melted piston
Scored up wall
Stocking up on z6, never know when you might need one..lol
Car when i got it
Fresh block back from machine shop, bored and knotch
ARP, GE, Vitara, TT
Co-worker showing some love on my build (Hyundai hubcap, I'm a Mazda/Hyundai tech)
MORE PICS AND PROGRESS TO COME....
Old 03-10-2008, 06:26 PM
Minh826's Avatar
Default Re: No SOL go to waste. (Minh826)
Found some more pics of the build.
Z6 assembled(waiting on oil pump from honda)
Engine is in, and running (so quiet, I was worried about the typical vitara noise)
She needed a good clean
As of right now i'm running it N/A to break it in. I gotta wait for some additional parts (Turbo kit, ectune boost controller, Innovative wideband, turbo timer, ect)
I'll keep updating on my progress...
Old 03-10-2008, 06:57 PM
Your Name's Avatar
singel slamin
Old 03-10-2008, 07:03 PM
Minh826's Avatar
Default Re: No SOL go to waste. (Your Name)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Your Name &raquo;</TD></TR><TR><TD CLASS="quote"> singel slamin</TD></TR></TABLE>
SOHC FTW!!
Old 03-10-2008, 07:43 PM
SuperSonikBluEK's Avatar
needs to be lowered
Old 03-10-2008, 08:19 PM
EKstacy's Avatar
Default Re: No SOL go to waste. (mugen666)
Nice save on the Sol. Good luck with the build.
And IMO.........<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSonikBluEK &raquo;</TD></TR><TR><TD CLASS="quote">needs to be lowered </TD></TR></TABLE>
Old 03-10-2008, 08:22 PM
ProMotive's Avatar
Default Re: No SOL go to waste. (EKstacy)
for PA. The taillights actually don't look too bad I need to do a turbo D-series build one of these days.
Old 03-10-2008, 08:23 PM
VTAC-KAT's Avatar
looks pretty good to me
Old 03-10-2008, 09:04 PM
EG-Kaos's Avatar
sweet build! o yea, what do you mean by vitara noise? the vitara pistons cause noise??
Old 03-10-2008, 10:04 PM
saywhat's Avatar
Default Re: No SOL go to waste. (EG-Kaos)
That thing has a mean stance on the stock suspension... Take it on any trails yet?
Old 03-10-2008, 10:47 PM
b17 turbo's Avatar
Default Re: No SOL go to waste. (saywhat)
just out of curiosity what did u time it at since the vitaras give it low compression do you have to advance the timing ? or do you still put evrything at tdc?
Old 03-11-2008, 12:40 AM
HONDACIVC93's Avatar
the vitaras run a little loose on a stock bore d series. but im assuming being as it was bored that its using over sized vitaras and your machinist is top notch and squeezed em in good . and he should run the same timing with lowered compression.
that thing is tight. very clean sol. i live up in the MN arctic so i dont get to see hondas without rust. whats the plan with the turbo setup? how much power you gonna try and make? good work and keep up the single cammin slammin!
Old 03-11-2008, 04:37 PM
Minh826's Avatar
Default Re: No SOL go to waste. (b17 turbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b17 turbo &raquo;</TD></TR><TR><TD CLASS="quote">just out of curiosity what did u time it at since the vitaras give it low compression do you have to advance the timing ? or do you still put evrything at tdc?</TD></TR></TABLE>
Timed it as a stock z6, no changes yet.
Old 03-11-2008, 04:40 PM
Minh826's Avatar
Default Re: (HONDACIVC93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HONDACIVC93 &raquo;</TD></TR><TR><TD CLASS="quote">the vitaras run a little loose on a stock bore d series. but im assuming being as it was bored that its using over sized vitaras and your machinist is top notch and squeezed em in good . and he should run the same timing with lowered compression.
that thing is tight. very clean sol. i live up in the MN arctic so i dont get to see hondas without rust. whats the plan with the turbo setup? how much power you gonna try and make? good work and keep up the single cammin slammin!</TD></TR></TABLE>
Thanks, i donno what set up i'm going with yet but i'll keep you updated. Hoping to make like 275 whp..ish
Old 03-11-2008, 04:44 PM
Minh826's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG-Kaos &raquo;</TD></TR><TR><TD CLASS="quote">sweet build! o yea, what do you mean by vitara noise? the vitara pistons cause noise??</TD></TR></TABLE>
Well i heard alot of talk about how the vitara set-up sound like a desiel motor, but mine is just like stock..
Old 03-11-2008, 05:01 PM
Minh826's Avatar
Thanks for all the good feedback, I just mocked up the Greddy FMIC today after work. Here's some pics.
Old 03-15-2008, 07:49 PM
Minh826's Avatar
Update:
Got bored so I started some body work. I'll be picking up a spoolin manifold and 3" downpipe, so the turbo will be in soon. Here's some pix:
Old 04-02-2008, 05:25 AM
Ep1dem1c's Avatar
got an extra z6 you want to unload?
looks good
Old 04-02-2008, 12:09 PM
JDM Lyfestyle's Avatar
Default Re: No SOL go to waste. (Ep1dem1c)
looks good so far..incase i missed it you decided what turbo to run yet?
what color you gonna go with?
Old 04-02-2008, 12:59 PM
andyfee's Avatar
Default Re: No SOL go to waste. (JDM Lyfestyle)
Nice work
Old 04-02-2008, 05:45 PM
Minh826's Avatar
Default Re: No SOL go to waste. (andyfee)
Ok, this weekend I fab up all the intercooler, welded up all the piping and the oil pan. All the AN fitting was a bitch :x , but all in all it was a good day. This week i'll be installing the ectune electronic boost solenoid, innovative wideband w/display..I'll keep updating as i go. Here's the current pics...enjoy
Old 04-02-2008, 05:57 PM
luvmihatch's Avatar
i like dat manifold... dats a nice manfold.
Old 04-02-2008, 06:16 PM
Krew126's Avatar
That looks so beautiful, when I get a car I was thinking about a Sol or an EG Hatch, but have to say that your Sol looks like it would be amazing and of course be pretty quick too. My first post here btw!
Old 04-02-2008, 07:13 PM
smokecdxx's Avatar
Default Re: No SOL go to waste. (luvmihatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by luvmihatch &raquo;</TD></TR><TR><TD CLASS="quote">i like dat manifold... dats a nice manfold. </TD></TR></TABLE>
lmao i see we are in the midst of a valedictorian...haha
on the bright side thats a clean sol
gl with the build
Old 04-02-2008, 07:51 PM
SkankyEJ7's Avatar
Default Re: No SOL go to waste. (smokecdxx)
Looks like a pretty complete build up.
Quick Reply: No SOL go to waste.
