No Radio blues make long drive longer...
Hello,
Bought another newer used Honda(94 Civic).
One of the battery terminals had corrossion build up so i removed the terminal
so i could clean.
Seems someone decided to add a little "feature" to the radio system, that if you disconnect the battery, the radio won't work unless you enter a pre-set 5 digit code. Does anyone happen to know if a master code exists or is removing the radio & taking the serial # to Honda dealer the only resolve?
Thanks.
so i could clean.
Thanks.
Re: No Radio blues make long drive longer... (kmslohnd)
that is factory. the code is. go to the audio/scurity forum and look around. there are guys there that can help you out.
take it to the dealer, give'm your car info they'll supply you with the code, it depends on the dealer if they charge or not
KHowe
03-19-2006 03:12 PM
