No Power to car
No Power to car
so i just did a simple swap in my 97 ek. so i have an issue. the radio and heater work. my foglights and corners work.
im not getting power to: starter, HID, taillights, climate controll, hazard lights.
am i missing something? i just pulled the harness out and everything looks fine. no cuts or exposed wires. both tranny and thermostat grounds are good and making contract. help i need this **** running so i can go to work tomrorow!
Re: No Power to car
Did you check all your fuses, grounds? Is the battery giving enough juice? Is the moter turning over at all? Does the fuel pump prime? Could be a relay.
Chris
Chris
Re: No Power to car
checked every fuse on the car and they're good. i even added 3 more ground wires from the batterie to the chassis. it's a optima yellow top batterie so it should have plenty of juice, like the car started and i drove it earlier. like while i was driving the tach died and fell to 0.
im getting fuel.
im getting fuel.
CTR LOVER LU
14
03-23-2010 08:36 PM
