No fuel on mini me, in a eg hatch
I just installed a a6 black and a y8 head. I'm using the y8 dissy casing and the z6 dissy guts. The main relay is good b/c it works on other cars. When I turn the key on the fuel pump doesn't prime up. If I take the relay out and put a jumper wire from pin 5 to 7 the pump comes on. If my dissy is a 180 degress off work it not let me pump come on??? I searched but didn't really find anything that would help me out. I need my car running asap. If I put the peice that goes on the dissy that connects to the cam on 180 degress off would it make that much of a difference.
Thanks alot,
Chris
Thanks alot,
Chris
Re: No fuel on mini me, in a eg hatch (civicboisi)
I'm here for help not to talk to smart asses. Plus I was in a hurry to get out of the house. I need help please thanks.
Re: No fuel on mini me, in a eg hatch (BoostedEgHatchFl)
i wasn't trying to be a smart ***...just stating the obvious...lot of people here won't even reply to half *** attemps for not asking questions correctly. Just a thought...
but bump for an answer for you
i think the ecu is not gettin any signal from the dizzy. did u cut or rewires the dizzy into the ecu
Re: No fuel on mini me, in a eg hatch (Ignitecivic)
All I did was swap out the guts from the z6 to the y8 distributor. The check engine light is on too
you said you jumped the pins on the fuel pump relay and it worked right than i think its you fuel pump relay thats bad and you should replace it. thats what i would do.
Re: No fuel on mini me, in a eg hatch (o5mar1)
I put the dx ecu in and pulled the ecu fuse for about 20 mins, and then put the ex ecu back it and it runs now
End3rx
02-22-2012 07:42 AM
