No fuel
No fuel
What I have is a 94 dx coupe that is not getting fuel. Basically I am putting my coupe back to stock since I have a 92 hatch that I put my Ls engine into. Everything should be plug and play but I let the car sit for about a year and now I am getting around to doing this. The car turns over nicely but no fuel. I have swapped relays between my two cars so I know that is good. I also put in a tested pump from the salvage yard. I have double checked my grounds which would be the under driver seat , shock tower, valve cover, transmission, and thermostat. Since I have two Dx ecus I have also tried swapping. All fuses have been triple checked. When I turn the ignition on neither the oil or the CEL come on. ANY HELP GREATLY APPRECIATED. Thanks.
Re: No fuel (92yellowEG)
I do have a new fuel filter ready to go on but the out going line from the one that is in there is stuck , I mean when I try to unbolt it , it seems like the bracket that holds it is bending to almost the point of breakage and squaw **** did not help. The wierd thing is that when I removed the fuel depressurization bolt on top of the filter there was not even a drop of fuel. Both cars were running when I originally did this. I also do not hear the second click of the relay so I believe it is electrical.
Re: No fuel (Endo-land)
yea mine had the same problem just get a 1/2" breaker bar on it with one hand then kind of lean on the bracket with the other hand, probably want to use a rag or something to keep from hurting your hand on the bracket. One more thing when you have KOEO (key on engine off) do you hear the fuel pump kick on?if not it might be the same problem mine has and no auto part store in my area can cross refrence it but it is under the driver side dash it is grey MITSUBA Relay ***'y main on mine but unpug it blow in both connectors plug it back in if it works then you know if not???
If the injectors are bad would it make the fuel pump not go? I guess I have not gotten that far up the fuel line as I dont have pressure at the filter.
thewhite_ricer
11
06-05-2009 06:54 AM
blinger
09-01-2007 10:35 PM
crnimacak
04-21-2006 10:11 PM
vtechicano
03-29-2003 05:53 AM
