NO A/C???
NO A/C???
ok so me and my friend just got done doing some work on my car... its 3 degress out side so i turn my heat on... it gets to hot and i go to turn it down.... and pop! my hot/cold moves super easy/freely!!! what the F*ck happend?!! and how do i fix it... like how do i take it out?
Re: NO A/C??? (justjoshin531)
what year is your car ?
all i know about a/c are on civic from 92-95 ... so maybe the wire that is attached to hot and cold **** snaped .. i guess that would explain the pop and the freely moving hot cold thingy ....
https://honda-tech.com/zerothread?id=1186091
that will show you how to remove the a/c unit ... there wire has to be disconneced and replace ... and you should be fine
HT White Ops
There is a cable attached to the slider on your climate control that goes to a bracket on your heater core. It opens a vent. The cable either popped off, or snapped. Check under your dash and glovebox area.
allmotorek8
02-21-2006 02:44 PM
projectej8
08-14-2005 02:43 AM
