next problem-CV joint. How tough?
Is the replacement Of the CV joint in a 92 civic better left to the pro's, or can do-it-yourselfer manage to get through it? Any and all input would be most appreciated.
Thanks, Dave |
Re: next problem-CV joint. How tough? (Dave P)
you might as well just replace the whole axle. its not hard to do at all.
here is a link to a clutch replacement faq but it shows how to remmove axles too...should take about 45 min. http://www.honda-acura.net/for...39802 https://honda-tech.com/forums/images/smilies/emthup.gif |
thats a good link it covers alot of info and buy a manuel on your car its your friend
Just get new axles, that way you dont have to pull the joint apart, repack the bearings yadda yadda yadda. I think its like 40$ for a new axle or something like that. but yeah 30-45 min. If youve ever unstaked your hubs then you pretty much know what you need to do, just have 2 new cotter pins per axle replaced (lower balls have castlated nuts) also its a good idea to get new hub nuts (its never good to reuse a staked nut)
Re: next problem-CV joint. How tough? (MilanoCivic97)
Thanks so much Milano. The photo's made the job easy!
Dave |
