Newbie swap help
Newbie swap help
first of all thanks for reading, and I have been reading on this forum for a while now, and I did search before posting.
I got a 92 si with a bad motor, and I found myself a wrecked 95 ls integra and bought it. So today I finally towed the integra. Now what I wanted to do is swap out the motor, tranny, axles, shift linkage, Complete Intake Manifold, Engine Wiring Harness, ecu, Distributor, Alternator. What else do i need????
I have many questions.
1. So since everything is still intact in both car, when doing the swap, what should I start taking out first? Meaning unbolt what stuff first inorder for me to swap out the engine.
2. Do i need to unbolt everything from the tranny, intake manifold, header, etc... from the engine before i lift the engine? Or can i just lift up everything together and drop it.
3. An about the wiring harness, do i need the wiring harness from the integra also, i read that my si one would work, but what do you think?
4. I want to swap the brake from the integra to the eg also, what do i need?
thanks.
ps, what other stuff from the integra would fit into the eg anyway????
[Modified by intezn, 12:33 AM 1/16/2003]
thanks.
likenother
03-18-2006 08:35 PM
