new trunk not aligning correctly
so i put on the domani trunk and the bottom hangs out few centermeters to far ... how to corect ? do i have to redrill the mountings holes to slide it in even more? or is ther a better solution ?the trunk doesnt look bent at alll looks perfect
Re: new trunk not aligning correctly
if i remember correctly the truck mounting holes are slooted so they should be adjustable
it should be a slow process of measuring, trimming a small portion, measuring again, trimming and test fits in between. remember since it is adjustable you can always move backwards if you end up going too far.
1 Post
just SLOWLY slot the holes down so you bring the trunk in....had to do it with my new trunk. just takes time. you will be happy when you have it all done.
