new rims causing rotors to warp???
is there any wat that new rims can make you rotors wapr my not getting anough air or anything??
Re: new rims causing rotors to warp??? (shaun311)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shaun311 »</TD></TR><TR><TD CLASS="quote">is there any wat that new rims can make you rotors wapr my not getting anough air or anything??</TD></TR></TABLE>
it it should not.. never heard of that before.. all though if the wheels are tourqed on to tight ive heard it can give you some weird problems.. make sure there on at 80lbs
are you guys sure 80 lbs?? it doesnt seem as tight as it should be... maybe that was my problem before
Did you go from stock size up to a 17" or 18" (or bigger)? If so, it takes more braking force to get those big wheels to stop. This means your mashing the pedal harder, which means more heat. Heat can cause rotor warp.
Re: new rims causing rotors to warp??? (realblag)
I would say your lugnuts got over tightened. This has happen to my 94 Ford F150 before when I got new tires put on it the place that mounted the tires and balanced them installed them and over tightened them and it causes the rotors to warp. Just loosen them up, and torque to 80 ft. lbs and it should get better if not go away as long as you haven't driven on them that way for like a year.
