New Head Gasket =Lower Compression??
Old 01-21-2004, 07:49 PM
Soccerking3000's Avatar
Default New Head Gasket =Lower Compression??
i would like to get a new head gasket for my d16z6 whch is going turbo very very soon and wsa wondering what size head gasket would be best cause i am not going to go with new internals, not going to be running high psi anywasy but would like to know, also how do u take the head off? is there a write-up somewhere cause i couldn't find it
thanks in advance
matt
Old 01-21-2004, 08:12 PM
SOHC_MShue's Avatar
Default Re: New Head Gasket =Lower Compression?? (Soccerking3000)
how much psi are you gonna boost? I wouldn't worry too much about it unless you are boosting higher and need a lower compression. Also search for bauleycivic's post on doing a minime head swap. That should help you get the idea of how to take off your head and all. Basically just drain all your oil and coolant, take all the lines off of your intake manifold and head, take off your valve cover, slip timing belt off cam gear, unbolt headbolts and take it off. I guess thats some of the basics of it.
Old 01-21-2004, 08:14 PM
TorganFM.'s Avatar
Default Re: New Head Gasket =Lower Compression?? (SOHC_MShue)
A 3-layer gasket would lower the compression I think. Check out: http://www.c-speedracing.com/howto.php lots of useful schtuff there.
Old 01-21-2004, 08:17 PM
Default Re: New Head Gasket =Lower Compression?? (DanW)
i plan on runny around 6-8 psi and as stated above with stock internals so lower compression is good
Ivan_JDM_hatch
12
07-13-2007 06:44 PM
raphael
02-16-2007 10:21 AM
p1ccoloz
04-21-2003 09:41 AM
ijjz
09-18-2002 06:55 PM
you2envious
05-26-2002 06:26 PM
Quick Reply: New Head Gasket =Lower Compression??
