New Ball Joint problem HELP, LOOK PLS
Brand new honda ball joint. 93 civic ex
i already messed up the boot (oops)
look at the picture, can you tell me where the c clip is supposed to be.
usually there is a reciever groove for the c clip to sit in, but this one is smooth.
Re: New Ball Joint problem HELP, LOOK PLS (Ls_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_dx »</TD></TR><TR><TD CLASS="quote">Brand new honda ball joint. 93 civic ex
ther is none on the energy suspension bushing. what i did with mine was, i just added alittle more bearing grease, threw on the boot right before i installed the knuckle to the LCA. once the joint, boot, and knuckle are together, the boot stays in place, keeping in the grease and protecting the joint.
Re: (Ls_dx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_dx »</TD></TR><TR><TD CLASS="quote">thanks for the reply, but, disregard the boot. im looking at the ball joint itself. there is no groove for the c clip</TD></TR></TABLE>
if i'm not mistaken the clip will go right underneath the top of the joint. there is a small groove already there. i can see it in your picture. it should be on the opposite of the threaded side.
Re: (Ls_dx)
Here's a pic of how it should look and where it goes after the ball joint is pressed in. Sorry so blurry. This was on one of my old Hubs laying around.
you really shouldnt have to use any clip if you have a good product it is a press in type and dosent need a clip. but if it came with one and I know all the aftermarket ones do then it should have a place for it like in one of the pics posted. but like I said with a good product it is not necessary. if you go get a oem one it wont come with a clip.
Re: New Ball Joint problem HELP, LOOK PLS (gsrhatch2356)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 »</TD></TR><TR><TD CLASS="quote">you really shouldnt have to use any clip if you have a good product it is a press in type and dosent need a clip. but if it came with one and I know all the aftermarket ones do then it should have a place for it like in one of the pics posted. but like I said with a good product it is not necessary. if you go get a oem one it wont come with a clip.</TD></TR></TABLE>
well the OEM one that i took out had a clip.....
huh, WHAT?! oem ones come with a clip, so you are saying oem ones aren't a good product? do you even know why the clip is there to begin with?
Re: New Ball Joint problem HELP, LOOK PLS (philosofy1)
no I am saying that the oem one is a good product and if you had a balljoint with a clip it is not oem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsrhatch2356 »</TD></TR><TR><TD CLASS="quote">no I am saying that the oem one is a good product and if you had a balljoint with a clip it is not oem. </TD></TR></TABLE>
OEM front lower balljoints have a clip you moron. I've swapped out a ton of em.
what? you never seen a oem joint before have you? oem ones have a clip!
The new style OEM honda ball joints doesn’t have a c-clip (honda realized it’s useless and not necessary) check the picture in my sig. The stock ball joint on my 00 civic doesn’t have a C clip either, and that ES dust/grease cover looks like a piece of **** (just like there crappy bushings)
Re: New Ball Joint problem HELP, LOOK PLS (sicones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote"> ES dust/grease cover looks like a piece of **** (just like there crappy bushings)</TD></TR></TABLE>
some one has a grudge against ES? got them on my suspension, and i'm quite happy with it.
as for the ball joint, didn't know the new oem ones don't have a clip. good to know.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ls_dx »</TD></TR><TR><TD CLASS="quote">So no c clip?</TD></TR></TABLE>
nope
nope
nope</TD></TR></TABLE>
cool, just get it hammerd in and its good
talk all that smack untill someone else agrees. real mature. and if you would have read my previous statement I clearly said that some do have it. but thanks anyway.
thanks everyone for the replies. i am using them, with no c clip. one with oem boot, then the one i messed up im useing the ES boot.
thanks again
thanks again
I Want An Si
11
02-13-2005 09:20 AM
