need wiring help asap - 94 Civic has loose Red/Grn wire in the loom
ok guys ive searched ,googled,yahooed,etc etc and cant seem to find what im looking for i have a 94 civic obd1 and while cutting back wires on the engine harness i found a red with green stripe wire loose in the loom. i tracked it back to the 14 pin connector on the engine harness on the passenger side can anyone tell me where this goes thx in advance
Re: need wiring help asap - 94 Civic has loose Red/Grn wire in the loom
Please make your thread titles as descriptive as possible - edited.
What electrical component doesn't work?
Guess #1:
Possibly the left high-beam headlight wire.
i need a for sure before tape everything up and heat shield the loom. also why would the left high beam be on the right passenger side engine harness?
Guess #2:
The picture shows the 14P C212 connector and the Red/Grn wire runs to ECU A21 and A22. C212 plugs into C103, which has the Yel/Grn wire from the igniter unit in the distributor. The Yel/Grn wire changes into the Red/Grn wire at connector C212.
The red and green wire onthe engine harness runs to the fire wall harness (Ecu harness ) which is where it changes to pink and white that wire goes into pin number 17 on connector d
Again, none of the wire colors you mention fit with those of the MAP sensor from an OBD1 Civic. So do we assume that a previous owner completely rewired your system?
Ya I think so cause I looked at a buddies eg and couldn't find those wires either o well I figured it out
B18aef
08-16-2016 06:02 PM
navin
14
03-10-2003 12:16 AM
